Head Gasket Sealer?
Cal B
10-19-2004 20:36:37
I am putting the cylinder head back on my JD 40 this weekend. Do I need to use any kind of gasket sealer on the metal gasket? If so, what kind do you recommend?
Thanks!
Cal B
Nacogdoches, TX
cannonball
10-21-2004 05:49:37
 Re: Head Gasket Sealer? in reply to Cal B, 10-19-2004 20:36:37
on metal gaskets that went on metal i always used aluminum spray paint..always worked..have nice day may god bless.....close to nacogdoches
old
10-19-2004 21:38:30
I always use whats called copper coat, it come in a spray can. Most auto parts stores have it
cody van meter
10-20-2004 18:55:36
 Re: Head Gasket Sealer? in reply to old, 10-19-2004 21:38:30
I use some called former gasket it seals pretty good i use it on every thing.
44 JD Model B
10-19-2004 21:36:08
I do recommend using a sealer. I tried to go without and had water seepage problems. I tried several different products before I found the Spray on Copper Head Gasket Sealer. Remember the smooth side of metal gasket goes against the block. Also remember to use the lead washers on your head bolts if that is what your service manual recommends, this also helps reduce leaking problems.
Hope this has helped.
Henry J
10-20-2004 05:23:59
 Re: Head Gasket Sealer? in reply to 44 JD Model B, 10-19-2004 21:36:08
44
I personally use nothing. I think the important thing is to have flat surfaces and the correct torque and sequences.
But you need to use what makes you comfortable is my theory.
It will work
