3 pt on 70???
jwill
10-19-2004 10:29:59
can a 3pt be added to a 70 standard?? How much trouble/expense?
jwill
10-20-2004 07:36:56
 Re: 3 pt on 70??? in reply to jwill, 10-19-2004 10:29:59
how much trouble if no rockshaft?? Thanks for the info so far!
JD Jerry
10-20-2004 06:21:06
I beleive I have a set of rockshaft arms for the 70 standard in my parts supply. Let me know if you need them.
Carl NY
10-19-2004 11:02:45
Not only do you need a rockshaft, you also need the rowcrop styled drawbar assenbly for the lower draft arm brackets. It can be done.
Hayfarmer
10-19-2004 10:50:11
Does it have the rockshaft ? If so you can pick up a JD 800 or 801 hitch, usually one on e bay or listings here, never cheap. Or you can get 3 point from Saginaw for it, not sure of price. If no rockshaft then it would be more problems.
