4020 gas distributor
Ryan
10-19-2004 08:28:20
Hello. I have been having problems with my 4020 gas, it will not run correctly. We tried electronic ignition and it would not run at all, went back to points and it runs but not very well. It will blow fire when deaccelerating and it makes no difference when pulling off spark plug wire 4, I believe. It has about everything common new in it. Could there be issues with the advance? We have checked the rotation, timing, and order multiple times. It has always ran rich as well. Any ideas? Does anyone rebuild these distributors?
thanks in advance
Ryan
Mike M
10-19-2004 09:55:38
 Re: 4020 gas distributor in reply to Ryan, 10-19-2004 08:28:20
I would suggest doing a compression test on it warm up the engine first then make sure the choke is not shut and the throttle is full open to allow air to enter freely. Won't hurt to check the adjustment on the rocker arms for proper clearance.
Bob
10-19-2004 08:52:59
You need to find out why #4 is not firing. A cracked distributor cap, or a badly worn or bent distributor shaft that is not opening the points when #4 is supposed to fire are possibilities. Have you replaced the #4 spark plug?
More likely, though, there's a mechanical problem with #4 cyinder. Does that cylinder have compression? How does that spark plug look compared to the others?
You could have a scored piston, bad rings, stuck or burned valve, pushrod or rocker arm problem, camshaft problem, head gasket problem, or a cracked head on #4.
When you find out what's wrong there, it will run a lot better, and then you can check out the spark advance, and adjust the carburetor.
Ryan
10-19-2004 15:55:13
 Re: 4020 gas distributor in reply to Bob, 10-19-2004 08:52:59
Compression on all cylinders were 125 psi across the board according to dad. Cap, wires, points, etc are all new. Tractor has always ran rich, wrong carb I am told, have switched manifold to heat the intake air as I do not work it hard (loader). I do not discount a cracked head, wondered if it could be something else.
Ryan
Mike M
10-19-2004 19:34:35
 Re: 4020 gas distributor in reply to Ryan, 10-19-2004 15:55:13
What kind of carb. do you have ? If it is one of those aluminum marvel schebulers throw it in the junk and get a cast iron zenith. Even one from a 3020 seems to work fine,thats what I found cheap to try on my 4020 and it was the single best thing I did to it.
Glenn F.
10-19-2004 21:55:49
 Re: 4020 gas distributor in reply to Mike M, 10-19-2004 19:34:35
How much gas will a 4020 use when working hard? It must have a gas line the size of a fire hose! Glenn
Ryan
10-20-2004 07:49:27
 Re: 4020 gas distributor in reply to Glenn F., 10-19-2004 21:55:49
I was pulling a 7.5 foot rear tine tiller with it one spring and I was figuring I was getting between 6-8 hours of working time on it. With a loader on it now we have ran it out of gas about 50% of the time. It has the second battery and many times makes a revolution and it is running.
Ryan
Mike M
10-20-2004 05:57:09
I don't know the actual amount of gas it uses.I usually don't run that many hours at one time.But you can run a lot through one the harder it works the more it sucks it up. The main reasons I looked for a gasser and bought one was cheaper price,starting in cold weather,and for the loader I do alot of starting and stopping short trips which I think would be harder on a diesel.
Gerald J.
10-19-2004 18:48:39
 Re: 4020 gas consumption in reply to Ryan, 10-19-2004 15:55:13
I've run onto my most thorough post. See the link below.
Ryan
10-20-2004 07:53:28
 Re: 4020 gas consumption in reply to Gerald J., 10-19-2004 18:48:39
I see a couple of things there that I think I had better check, such as the choke cable and the donaldson air cleaner. Mine currently does the smoke like a diesel. I have the cast iron zenith.
Ryan
Ryan
10-20-2004 07:57:55
 Re: 4020 gas consumption in reply to Ryan, 10-20-2004 07:53:28
Actually upon further thought it looks alot like a marvel schebler carb, cast iron, like you might find on a moline G or something like that. Once, someone told me that this was not the right carb, that is was off a combine, but this carb does have the solenoid build into it on the block side of the carb. Is this the side yours is on?
Ryan
Gerald J.
10-19-2004 18:34:56
If it runs rich, first replace float needle and seat. Then while its apart be certain that float floats. If it still runs rich with those parts fixed, then adjust the float to be lower in the bowl when the needle closes. There is also a high speed adjustment in the shut off solenoid. A little flat slotted screw right in the outer end.
I'm sure I posted about fuel consumption in the new generation tractor in the last two weeks. With much detail. Check back for that. I'm not at home and need my spell checker to do it right to post it again.
Gerald J.
Ryan
10-20-2004 07:55:12
 Re: 4020 gas distributor in reply to Gerald J., 10-19-2004 18:34:56
My solenoid is not connected at this point. Will screwing the screw in make it leaner?
Ryan
Heat Houser
10-19-2004 22:24:44
Aluminium Marvel Schlebler carb. thoughts.
My 4010 was running way rich and backfiring thru the carb. Found the accelerator pump diaphram had a pin hole in it allowing it to suck gas at all times. I have gotten tired of messing with it so after drinking some beers, I cut the can into strips, removed the back (float) cover and blocked the ports. Wish I had done that years ago as it runs the best it has ever had.
Mike M
10-20-2004 10:55:18
 Re: 4020 gas distributor in reply to Heat Houser, 10-19-2004 22:24:44
I still have mine maybe some puller will want it as they won't have much need for an accelerator pump.
