Ground Hook-Up
Tugboat
10-19-2004 03:29:56
I haven't been able to determine if my late styled 12 volt JD AO s/n 278782 with two 6 volt batteries uses a positive ground. Can you clarify this for me? Thanks, Tugboat
John T
10-19-2004 06:31:56
 Re: Ground Hook-Up in reply to Tugboat, 10-19-2004 03:29:56
Tug, ALL 2 cylinder Deeres used POSITIVE ground. The POS of one battery is grounded (i.e. Pos ground),,,,,its - connects to the other batterys + ,,,,, ,,,,and that second battery - is what gets connected via the starter by a big cable.
John T
Tugboat
10-19-2004 17:13:56
 Re: Ground Hook-Up in reply to John T, 10-19-2004 06:31:56
Thanks, John! I'm thinking of using one 12 volt battery instead of two 6 volt batteries in this parade tractor. What do you think of this?
Tugboat
Gerald J.
10-19-2004 18:37:16
 Re: Ground Hook-Up in reply to Tugboat, 10-19-2004 17:13:56
You can't pick up the single 12 volt that does the job of the two 6 volt batteries. Look for a 12 volt with the same CCA as a 6 volt.
Gerald J.
