Fuel tank liner
TPat
10-18-2004 18:56:35
I have a gas tank on a JD 620 that is in pretty rough condition. Will the liquid fuel tank liner work??? My tank is pretty rusty with some small/minor holes that have been repaired with what looks to be JB Weld. The rust scale keeps stopping up the fuel line from the tank. What product/company would you guys recommend??? Thank you! TPat
Mike M
10-19-2004 07:38:01
 Re: Fuel tank liner in reply to TPat, 10-18-2004 18:56:35
Type RED-KOTE in the archives under tractor talk I posted all the address and phone number for the company.
He who used to be Greg S
10-19-2004 10:02:27
 Re: Fuel tank liner in reply to Mike M, 10-19-2004 07:38:01
Mike, Thanks for the information. For those of you who have yet to do the search, simply type the words RED KOTE. Leave the hyphen out, or it will not work.
John Van Valkenburgh
10-19-2004 01:24:00
I've used the liquid fuel tank coatings a couple of times with good sucess. The first one I used was a single-step process. It was made for marine applications. They recommend putting a chain in the tank and thrashing it around a bit to loosen the big stuff. I coated the tank a couple of times. This tank did not have any holes in it though. It was simply dropping rusty flakes into the fuel screen and stopping the fuel flow.
The second tank sealer I tried was for an old Allis-Chalmers CA. It was a 3 step process. One bottle was for cleaning, the second for etching and the third for coating. Again I used two coats. This tank did have pin holes when I started. Sealed up fine. The 3 step sealer was designed for motorcycles and any motorcycle dealer should have some.
I think it's important to allow the stuff the throughly dry. At least a day between coats and perhaps a week before you use it. I don't think the instructions requires such a long drying process though.
Best of luck,
John
1953 Model 50
Marty Z
10-18-2004 23:00:37
I was led to a sealer called RED-Kote. I bought it local in toledo Ohio.
Look it up un the web. I was surprized how well it worked. It stays like rubber on the inside and it sealed all the small leaks too. It captured all of the small flakes that were ready to fall off and it seems to be working great on my GP. My GP tank was in real bad shape so I cleaned the inside the best that I could, Soldered the big holes from the outside and coated the inside. I would coat it twice next time to be sure,, but the single coat seems to be working fine. 2 quarts worked for me on a double tank , but next time I would buy 4 quarts and really coat it twice. It was only about , $ 16 a qt
Martin Zielinski
Curtice Ohio
jdemaris
10-18-2004 19:02:39
I used it on motorcycle tanks I was restoring, but also used it on few tractors. It works better than I'd ever anticipated. Seems the stuff I used was called Kreem. I'm still riding my 1959 Royal Enfield and it was 1979 when I fixed the tank with the stuff. That's pretty good. Seems though, if you're going to use it on a large tank it's going to take a lot of sealant. Here's one link that's sells it:
http://motorcyclecity.com/Parts/tank-repair.htm
TPat
10-19-2004 04:24:34
 Re: Fuel tank liner in reply to jdemaris, 10-18-2004 19:02:39
Thanks to all for the information and recommendations. TPat
