4010 diesel to a gas
Peter Olmstead
10-18-2004 17:10:56
I am putting a gas engine from a 105 combine into a 4010 diesel engine, what can I use and what do I need to change. Can I use the same fly wheel off the diesel engine? What about the exhaust manifold? Is there anything else I need to do?
HTR
10-20-2004 10:05:51
 Re: 4010 diesel to a gas in reply to Peter Olmstead, 10-18-2004 17:10:56
Peter, the flywheel from the diesel will work on the gas engine. There is a possibility that the center hole in the flywheel will have to be machined out to fit the combine crank. I would be interested in buying the the flywheel from the gas engine, and the flywheel housing from the combine engine, if they are for sale. You won't need them for the change over.
Peter Olmstead
10-20-2004 14:48:07
 Re: 4010 diesel to a gas in reply to HTR, 10-20-2004 10:05:51
yes they are for sale. Do know if a Exhaust manifold with a heat valve fit the gas engine without change the Intake that dosen't have aExhaust heat valve. Sent me a e-mail. I will be gone for the 6 days .
farmerboybill
10-19-2004 05:29:17
What is the status of the diesel engine? I didn't think anyone would want to go diesel to gas but I guess it takes all kinds. Don't let someone give you 500 bucks for a good diesel engine as it's pry worth more like 2 grand.
Call a tractor parts supplier in your area and tell them you're looking to turn your gas into a diesel and see what kind of price they give you. Knock 1000 to 1500 off that price and your block is worth that if it's in good running condition.
Peter Olmstead
10-19-2004 05:39:20
 Re: 4010 diesel to a gas in reply to farmerboybill, 10-19-2004 05:29:17
They had lock the engine up and did not want to put $3000 to rebuild it,they had a 105 gas engine sitting around .
GREEN
10-18-2004 19:02:52
Could I get your tel # or e mail address. I have any parts you might need. I might be interested in your old motor if you still have it.
Peter Olmstead
10-18-2004 20:34:28
 Re: 4010 diesel to a gas in reply to GREEN, 10-18-2004 19:02:52
Let me know what you have and the price.The Tractor belongs to a freind of mine, I do not know what he wants to do with the motor?
Peter Olmstead
10-18-2004 20:43:28
 Re: 4010 diesel to a gas in reply to Peter Olmstead, 10-18-2004 20:34:28
I am looking for Exhaust manifold,Air Cleaner, air intake pipe & hose. there maybe some other thing I need.
