4020 PTO Slipping
Ricky in Texas
10-18-2004 16:03:06
I have a "70 model 4020 with the syncro transmission. When I engage the pto to run my batwing it spins up but when I hit tall grass or bushes it slows down and won"t cut. After I get in a less dense area it spins up fast again.
I smell a slight burning of something - maybe the pto clutch? Does anyone know if I can adjust it out or does it need to be broke apart to be repaired? Advice appreciated.
Ricky in Texas
10-19-2004 05:27:57
 Re: 4020 PTO Slipping in reply to Ricky in Texas, 10-18-2004 16:03:06
Thanks for the quick replys. It is a great tractor and I want to keep it going.
I will take your advice and hopefully it will solve the problem. Thanks again.
B.B.
10-18-2004 20:15:18
Check the pto seal. 4020"s are bad about the pto seal leaking. Take the inspection plate off and see if hydraulic oil comes out. If it does it is the seal. It slings the oil on the clutch causing it to slip.
jdemaris
10-18-2004 18:40:40
That PTO setup engages by putting pressure ON the clutch plate fingers which is kinda' the opposite of most clutch setups. Deere 4020 synchros do this in two different ways depending on the serial numbers. The older models use mechanical linkage that pushes a bearing INTO the clutch plate fingers in order to engage. It is easy to adjust through the bottom trap-door. I hesitate to call it a "through-out bearing" since it is actually a "through-in" bearing. Later 4020s use a hydraulic engagment system. Instead of mechanical linkage, there are two small hydrualic pistons underneath that push the bearing into the clutch-plate fingers. You should inspect the PTO clutch by looking at it, with the tractor hot and running with the PTO engaged and see if the bearing is pushing forward and staying engaged, or if it's wandering in and out - or leaking oil. You CAN adjust the clutch fingers from underneath to get more pressure on the clutch, but that's not going to fix it if the PTO clutch disk is worn out. If you adjust the fingers, make sure, when the PTO clutch is disengaged, the bearing does NOT make contact with the fingers. If it does, it will eventually burn the ends of them off which I used to see happen a lot (when I was a Deere mechanic).
jdemaris
10-18-2004 18:43:06
 Re: 4020 PTO Slipping in reply to jdemaris, 10-18-2004 18:40:40
Just realized I spelled "throw-out bearing" wrong. Oh well, it's probably from brain damage from being greasy for 50 years.
