F125 Plow Trip Problem
RB70D
10-18-2004 10:58:17
I have a 3 bottom F125 plow that the first and sometimes the second bottom trips way too easy. I have put in new kits, larger trip bushings and tightened the pivot bolts. The plow is pulling level and set up to exact John Deere specs. The ground is ideal and the other plows have no problem.
Johnsdeere
10-18-2004 19:50:55
 Re: F125 Plow Trip Problem in reply to RB70D, 10-18-2004 10:58:17
I have a 3pt 4 bottom JD plow, probally the same style trip set up. A roller on a lever that is held with pressure on in the groove by a spring? I have the same problem with my second bottom, trips so easy that I finally put a chain on it to keep it together until I can fix it some how. I had thought that maybe the spring was weak or weakend by rust? My roller seems to be in good cond. I need help on this too. Thanks
ET
10-19-2004 09:12:28
 Re: F125 Plow Trip Problem in reply to Johnsdeere, 10-18-2004 19:50:55
Try changing places withe the bottoms and trip standard by taking out the pivot bolt on the bottom that trips and switch it with a good one. If the trip problem moves with the standard then the knotch for the roller is worn.
ET
10-18-2004 13:01:25
The standard is worn where the trip roller latches. You can try and build it up with a spot of weld and reshaping it with a grinder but then it may never trip at all. I did one on my plow and have done my best to shape it like the unworn standards but I haven't seen it trip at all since and I took out all the bushings.
