P.S.... Looking into the pump with the fitting out, the fuel level is not supposed to drop. The pump remains full of fuel for cooling and lube. The pump gasket and seal kit is only about $30.00, and it is possible to disassemble the pump and replace the dampner ring without disturbing the calibration of the pump. A new plastic ring will last for years, and a few thousand hours of run time, and there's also a update kit that is available for about $90.00, that is a more permanent fix. This requires professional installation because a new timing mark must be made on the new part after installation. You can get an injection service manual from Deere, or find one on ebay. There's some manuals there on CD that sell pretty reasonably. You almost have to have a special Roosa tool (a tapered plastic sleeve) to install the pump shaft seals, and there is a screw (Torx) in the bottom of the pump, in the advance, that requires a matching bit to remove, and you should have a special tool, which is a sleeve that slips over the ballhead on the end of the screw to keep it from expanding and splitting, as it is very TIGHT.
