30 series cold starting problems ( problem is fixa
Johnsdeere
10-17-2004 21:03:12
third party image
John Deere has a Intake preheater available now for 30 series tractors. Only problem PRICE, apears to be $600 for the complete kit, with controller. I tried to price just the intake with heaters so I could run a push button switch to a relay so I would not have to have it controlled by temp. But that appears to be over $650. Has anyone tried this fix? Is it worth it? I have thought about a magnetic engine block heater to put on my intake before starting.
Dave Thuesen
10-18-2004 14:26:02
 Re: 30 series cold starting problems ( problem is in reply to Johnsdeere, 10-17-2004 21:03:12
Hello there, I overhauled my dads 4430 2 yrs ago with the updated pistons. It now will start fine at 25 degrees with no either. Anything below that I plug the block heater in and it has now problems what so ever. Your block heater, if it is working should be more than enough to start it unless you have other starting troubles. Dave in Jesup
Stuart
10-18-2004 10:41:05
I have not heard of this. but one thing I would try is putting in a block heater and a oil pan heater.This works really well on some of the Deeres we use. hope this helps.
