50 radiator leak
Dan50
10-17-2004 20:15:06
Got a nasty leak AFTER I changed the coolant on the radiator today when it wasn't leaking before! There was a whole lot of filth that I flushed out... I suspect it was plugging the hole or crack shut.
What's the best leak stopper to try and plug this thing with, short of pulling the radiator out? Right now, I don't run the tractor real hard, mostly take it out to pull the kids around on the wagon with .
Thanks - Dan
John Van Valkenburgh
10-17-2004 20:37:24
 Re: 50 radiator leak in reply to Dan50, 10-17-2004 20:15:06
Hello Dan,
I think you are correct in that the "crud" you flushed out of the radiator was keeping it from leaking. Personally I would not recommand putting in any kind of "stop leak" radiator additive. That stuff just seems to get everywhere and I think you would be forever getting it flushed back out of the system.
Is the leak somewhere you can see? If so I'd drain the coolant down below that point, clean up the metal with fine sandpaper till it's pretty much shiny. Next dab some plumbing flux on the area, heat it up with a propane torch and solder it.
I have seen some radiator fixes that were not additives. These would be okay in my opinion at least temporarily. You might also try something like JB weld on the leak.
Best of luck. Rebuilding the radiator is hard work. Nothing particularly complicated, just that it has two heavy castings and there will be a few or more broken bolts when you take it apart. Nothing you can't fix though...
John
1953 Model 50
Dan50
10-18-2004 20:05:07
 Re: 50 radiator leak in reply to John Van Valkenburgh, 10-17-2004 20:37:24
John-
Thanks for the suggestions. Although I haven't had the chance to inspect it too closely, it's only leaked btween a qt. and half-gallon. I would assume this may indicate the hole is somewhat high up on the radiator.
What type of solder would you suggest if I were to go that route?
Thanks, Dan
10-19-2004 01:34:13
 Re: 50 radiator leak in reply to Dan50, 10-18-2004 20:05:07
Dan,
That cooling system should have something like a 7 gallon capacity (mine was a little over 6) so it does sort of indicate a leak up pretty high. Either that or there is some loose stuff starting to fill the leak again.
The solder I recommend is the same as is normally used in house plumbing. It's generally solid (as opposed to electronic-type rosin core). I use a little of the acid type flux. This helps to clean the area and improve adhesion. You don't want to ever use acid flux in electronic applications though...
The secret is getting the area clean (if possible shiny) and then getting it hot enough for the solder to flow. Heat the work not the solder. When the radiator is hot enough to melt the solder you apply to it you're cooking.
A propane torch should do nicely.
Best of luck,
John
1953 Model 50
Dan50
10-19-2004 15:04:49
 Re: 50 radiator leak in reply to John Van Valkenburgh, 10-19-2004 01:34:13
John,
Once again, thanks for your info. Actually, my radiator took about 4 3/4 gals., and that's exactly what the manual said.
-Dan
