Belt Pulley for JD 630...
Ron
02-07-2004 10:00:21
I have one with a piece broken out on the clutch-brake side, and need a replacement.. Will any from a 60, 620, and 630 fit..?? If I gave the measurements, could someone cut out a piece from another broken one, so I could weld it in..?? I had never seen breaks like this on ours..!!
I hope everyone KNOWS-NOT to Force those Clutch Bolts..!! If someone has one that is good and fairly priced, I would like to hear from you..!! I am in Central Ohio.. Thanks..!! Ron.
Brokenwrench
02-07-2004 16:12:15
 Re: Belt Pulley for JD 630... in reply to Ron, 02-07-2004 10:00:21
Dengler's has rebuilt pulley wheels for 630's.You can possibly trade in your old wheel. The rebuilt one will come with welded in latching dog pivots which will alleviate future engagement/disengagement problems. www.denglertractor.com or513-423-4000
John T
02-07-2004 10:28:20
Ron, I can confirm what the good clooney man found, cuz I have a broken 620 clutch pulley and was told (plus saw the difference) the same thing, a 60 WONT WORK and I dont even think a 630, but I will have to check my parts book for a definite answer on that one. I Will get back to ya.
good luck , God Bless
John T Nordhoff
Ron
02-07-2004 11:02:48
 Re: Re: Belt Pulley for JD 630... in reply to John T, 02-07-2004 10:28:20
Thanks, John T...!!
Thanks, too, Clooney..!! If ya "trip" over one, let me know..!! I can't believe how many of these have been ruined...!!
Clooney
02-07-2004 14:04:49
 Re: Re: Re: Belt Pulley for JD 630... in reply to Ron, 02-07-2004 11:02:48
Ron, if you call around you shouldn't have any problem finding one but you will probably pay dearly for it.. Problem is there aren't that many late model Deere's being parted out as they are worth so much in running condition...
~A lot of those pulleys get broken while trying to press the drive gear off & on without supporting the center hub..
~If you just need that pulley to look good you could hammer form a piece of 1/4 " steel to have the correct radius,, then weld that in, then stick the pulley on a lathe & turn it until the patch matches.. A little urethane filler primer & fresh green paint & it will look good as new.
[email protected]
John T
02-07-2004 13:00:00
You're sure welcome and likewise, if you trip over one for a 620, let me know please.
John T
Clooney
02-07-2004 10:12:53
Ron, I show the 620-620 used the same A 5500R pulley but the 60 used a different pulley.
[email protected]
