JD 4230 starter with hydraulic fluid in it
Kevin Mosley
10-17-2004 15:15:30
My JD 4230 all of a sudden got really hard to start. Thought my batteries were bad. Tested good. Pulled the starter off and hydraulic fluid/transmission fluid ran out of the starter when I turned it on its nose. Anybody gat an idea what seal is bad or what else may be wrong before I tear into it?
Bob
10-17-2004 19:30:14
 Re: JD 4230 starter with hydraulic fluid in it in reply to Kevin Mosley, 10-17-2004 15:15:30
The nose of the starter runs in transmission/hydraulic oil. There is a seal in the starter next to the center starter bushing.
You may just have a bad seal. The starter may need bushings, or the armature shaft could be bent or damaged.
oldjdguy
10-17-2004 17:01:52
May only be the starter itself going bad. I believe the Perma Clutch housing runs wet and thus the starter nose and starter pinion gear see the oil. The starter must have a seal in the nose some where to keep the oil out of the armature. I"d do a thourough starter test, check fields, armature, brushes, etc before looking at the clutch housing of the tractor. My ideas - others out here probably know for sure.
Kevin Mosley
10-19-2004 19:03:50
 Re: JD 4230 starter with hydraulic fluid in it in reply to oldjdguy, 10-17-2004 17:01:52
There is a seal in the starter and the clutch housing does run wet. My seal was bad in my starter. Thanks for the help.
