3020 hydralics
old feed man
10-17-2004 13:40:58
I have a 1968 JD 3020, When you start the tractor it takes 5 to 10 seconds before the hydralics work, and once they start they work well, even with the clutch in. Any ideas?
Gerald J.
10-17-2004 13:54:49
 Re: 3020 hydralics in reply to old feed man, 10-17-2004 13:40:58
Probably a hydraulic leak in a valve but it could still be the check valve in the transmission. Might just be very low on oil. I've seen 3020 lift the three point with a load on it before the diesel fired in cold weather, and I have learned to not put my foot on my 4020 brake pedals before starting it. The pedals rise rapidly and with force as the pressure comes up in the first half second of running.
If its the check valve, I have the JD service information for replacing it on my web page:>Link
Gerald J.
old feed man
10-21-2004 13:47:37
 Re: 3020 hydralics in reply to Gerald J., 10-17-2004 13:54:49
Thanks I will order the parts and give it a try
