3010 Positive Ground ?
gotperchs
10-16-2004 19:41:21
I"ve got a 3010 that has eaten up 3 generators in two years. I have installed my third generator and new voltage regulator to find that with the ignition off the generator light kept blinking on and off. I have come to learn that 3010"s are positive grounded. What damage have I caused by the battery being hooked up as a negative ground system? What should I do to remedy the situation? If I simply switch the ground to the positive terminal on the battery and repolarize the voltage regulator will I resolve the problem. Hopefully my battery will charge back up after starting and all systems will operate properly. I appreciate any help anyone can give me. Thankyou David
gusc
10-17-2004 19:58:45
 Re: 3010 Positive Ground ? in reply to gotperchs, 10-16-2004 19:41:21
Sorry, I meant 3010.
Forgot to add that a battery disconnect switch is a very good safety item and battery saver. I have them on all my old trucks and tractors.
I call them the "green knob" switches. They are available at WM for $2.95. They sure are great when a starter sticks or a shorted wire starts making red hot wiring and smoke and just for general maintenance.
gusc
10-17-2004 19:52:09
When you polarize always do it with the regulator wired to the gen and the whole system. This keeps the gen and regulator working together.
There is no real reason to go back to pos ground. The only reason it was done in the first place was "everyone else did it". Neg ground will possibly prevent an accident down the road when an innocent person tries to jump it not knowing it is pos ground.
An exploding battery is not a pretty sight.
If your 2210 is gas and you have the original coil that was used with pos ground you need to change the switch wire to the neg terminal on the coil. It doesn't make a lot of difference but will slightly increase the engine power.
John T
10-17-2004 08:00:33
Got, Other than possibly the battery not being kept charged or becoming discharged, you may not have damaged it much to this point. Many Voltage Regulators are bi polar and will work at POS or NEG Ground, but may not last as long if used reversed. Yes, you can remedy the situation by attaching the battery POS ground and re polarizing the Generator, try that n see how she does.
John T
Bob
10-16-2004 20:22:45
If you have the generator light "ON" without the key on you have a short in the wiring harness, wires connected wrong at the regulator or the switch, or a defective regulator. (The reason it blinks is that the bulb is a blinker bulb.)
When you polarize, what you are actually doing is magnetizing the field coils of the generator so that when the engine is started, the generator will charge with the polarity matching that of the battery. A tiny amount of magnetism (residual magnetism) remains in the iron core of the magnets, and causes it to begin charging at startup.
