JD 60 hydraulics question
Haymaker
10-16-2004 19:07:26
I have a 60 and just put a #45 loader on it and have a small problem. The loader raises properly but when you let it down it"s as if it is fighting the hydraulic pump. It will go down but very slowly and it forces hydraulic oil out around the pipe fitting where the coupler is attached. The hoses attached to the rear of the cylinders are coupled to the lower fitting and the return end hoses are connected to the upper outlet. The resiviour is not over full. Could this be a check valve problem ?
Stuart
10-18-2004 10:42:32
 Re: JD 60 hydraulics question in reply to Haymaker, 10-16-2004 19:07:26
Try switching the remote hookups on the back
