2640 Water pump
JD Jim A.
10-15-2004 20:05:54
Bought the 2640, Diesel engine, and right away, the water pump started leaking. Got it off of there today, tried to start tearing it down, cannot get the pulley pressed off, even with a very large hydraulic press. Someone suggested using an air hammer, not sure what they meant, support the pulley and hit the shaft with the air hammer? Any other tips for repairing this pump?
cannonball
10-16-2004 06:06:05
 Re: 2640 Water pump in reply to JD Jim A., 10-15-2004 20:05:54
i awalys used a puller to get pulley off.. then pressed out bearing..cleaned up pressed bearing back in pressing on outer edge..install seal with tool in kit..then put impellar on according to specs..put something under shaft on impellar side and press pulley on according to specs....have nice day may god bless
