4630/fwa convert
okiedirtfarmer
10-15-2004 19:17:34
Here"s one thats off the wall. I have a 1977 4630. I would like to make it a fwa. I have read of the short coming of the john deere system that was available on these tractor befor the 50 series mfwd models. So...could the transmission out of one of the later models be put into a 4630 along with the mfwd axle. Next...Would it cost more than the tracto is worth. It is still an excellent tractor. Nearly 16000 hours, with just over 5000 on the overhaul. Original paint that looks nearly as good as new. I just compounded and waxed it yesterday. Even if it is expensive to do I bet it would cost much less than updating to a later mfwd. I just need a little more help to pull my 40 foot set of full press 9000 series John deere drills. Like I said this may be a total impossibility, but you never know without asking.
david val
10-17-2004 10:57:36
 Re: 4630/fwa convert in reply to okiedirtfarmer, 10-15-2004 19:17:34
i am not from the US, so there is much i don't know about prices etc. but the idea seems unpractical. you actually try to fit a 4630 engine into a 50/55 series tractor, why?
if you like your 4630 for sentimental reasons- keep it! you can get an extra mfwd 50/55 series tractor, probably for less then the 'conversion'.
david
okiedirtfarmer
10-18-2004 19:59:52
 Re: 4630/fwa convert in reply to david val, 10-17-2004 10:57:36
You must know where to buy 50 or 55 series tractors in this same size range cheaper than I do. I am not wanting to change engines. I was wondering about putting a transmission in that had the shaft to run a mfwd and adding the mfwd axle. If it was possible, I would be willing to bet I could buy the parts from a used parts dealer for less than a 4650 or 4755 would cost, unless they were ungodly high houred. In that case I dont want them.
Jerryh
10-15-2004 19:36:54
You might want to consider the hydraulic driven FWA. I believe it was a 4850 that I put an engine in that had the hydraulic setup on it. It looked pretty simple and a salvage yard would have the parts. I have heard that the mechanical is probably better but combines have hydraulic mud hogs and they seem to work pretty good.
