How Much Compression on 1952 JD B?
Charles
02-07-2004 07:42:29
Does anyone know what the compression readings (pounds)should be for 1952 JD B 190.4 cu.in. engine? What is the maximum and minimum?
Thanks Charles
Clooney
02-07-2004 09:37:05
 Re: How Much Compression on 1952 JD B? in reply to Charles, 02-07-2004 07:42:29
Charles, I show the late Deere "B" All-Fuel at 70 psi cranking [hot engine with choke & throttle wide open]...& the late "B" gasoline at 110 psi cranking [again hot & with the choke & throttle wide open]..
~As far as min & max compression.. Max probably doesn't mean much as long as it is within about 10 psi on both cylinders.. Min could be a problem if more than 10-15 psi below the given but again the important is within 10 psi or so between cylinders..
[email protected]
Duane Larson
02-07-2004 09:02:00
Charles,
John Deere Field Service Bulletin 212 (2/54) gives 110 psi for the gas B at rated engine speed (1250 rpm for your B). Deere recommends belting the tractor to another, adjusting speed to rated rpm, and measuring compression.
Pressure at cranking rpm is not given, but studying a later FSB which gives compression pressures for both cranking and rated rpm for the numbered series tractors shows a ratio of 0.8 (with an uncertainty of 5%) for cranking to running psi. So, this implies a cranking psi of 110 x 0.8 = 88 psi (range of 5% gives 84-92 psi) for your B.
These numbers are also with the throttle and choke wide open.
