3020 pop
Randy H
10-15-2004 11:46:05
After running my 3020 from time to time 10-15 seconds after I shut it down it will back fire hard enough to blow the muffler cap off. It was just timed according to the book.
thanks in advance
MSS3020
10-17-2004 20:02:00
 Re: 3020 pop in reply to Randy H, 10-15-2004 11:46:05
Agree with both I usually idle for 2 minutes..usually while backing in to the shed or coming up the drive to the shed. that takes care of the problem..
Bob M
10-15-2004 12:13:11
That's not unusual. We have a 3020 that does that sometimes too. Also a Minnie Mo U, an Oliver 1600, a Gravely zero turn mower, a B&S powered leaf blower, etc.
Is caused by unburned fuel that gets blown into the exhaust manifold/muffler as the engine coasts down, and which then ignites explosively on contact with the hot metal there.
Solutions are to let the motor slow idle for a couple of minutes (to let the manifold/muffler cool), and making sure the governor is fully closed before hitting the switch.
Note: Ignition timing has no effect on shutdown backfiring since there is no spark to the plugs once the ignition switch has been turned off.
DON
10-15-2004 12:06:36
USUALLY IF YOU LET IT COOL DOWN MORE IT WONT DO THAT. USE THE SLOW IDLE POSITION HELPS. SOMETIMES WHEN THEY DO THIS IT WILL BLOW A HOLE IN THE ACELERATOR DIAPHRAGM IN THE POT METAL CARB CAUSING IT TO IDLE ROUGH AND BURN A LOT OF GAS.
