Help on buying JD 450 dozer
Thor wicklund
10-15-2004 11:02:21
I am in the market for a small dozer to clear brush, small trees etc.. I have found a 1970 jd 450 dozer with a 6-way blade. the undercarriage has been gone thru, as well as the engine. Hourmeter shows 4500 hours. The machine is in nice shape. The guy is asking $12,000. My questions is, is this a reasonable price and also is this dozer large enough to push over smaller trees, or do you have to dig around every tree you come up to. Can you run over a 6-8" oak tree, back up and push the stump and tree at once. The type is T5F3M and serial number is 106530T, can someone help me with the year and what type of HP does this thing have. Thanks
Lavoy
10-16-2004 16:31:00
 Re: Help on buying JD 450 dozer in reply to Thor wicklund , 10-15-2004 11:02:21
Seems a little high unless he can show a whole bunch of receipts for work other than the trans.
I would doubt the hours. Like someone else posted on this subject somewhere else, that dozer probably had that many hours in the first 3-5 years. Lavoy
CraigE
10-15-2004 17:30:44
Thor,
I have a 450 for sale right now that I would take a lot less for than what you quoted. The price you quoted would, I think, be more for a later model, a 450B or C series. Depends on the area, though. Mine has a B series engine, I think, and is about 76 hp, but the original A series was about 67 hp.
Once you learn how to undercut the root systems on most trees with the first pass, the second pass will push them out if they are 8" or under. A lot of trees this size will come out with one pass. Some pinoaks have a taproot that makes you dig a while. Trees over 12" will take you a while. But the 450 is a great dozer if they have been cared for at all. Be sure to buy one with a rollover cage and limb risers, even then it's easy to pinch yourself if you don't watch out.
Let me know if you have more questions.
PS buy the parts and service manuals and you'll be able to do quite a bit of work on these.
CFWelles
10-18-2004 03:48:11
 Re: Help on buying JD 450 dozer in reply to CraigE, 10-15-2004 17:30:44
Good comments on the 450 fellows. I have owned a 350C from 400 hours since 1980 and it is a great little machine. Have run my brother's 450B some as well. You guys are right on about taking out an 8" hardwood. Softwoods are much easier. I have pushed over 24" stumps with my 350C after working on them for about an hour. If you go around and root out the stump, eventually you come down to just pushing out a ton or so of dirt and wood. After digging them out, getting on the tangent of the root ball and giving it a twist is the most effective way to disloge the stump. This literally twists the remainingl small roots under the stump off. Also agree that 12K is a little salty for the 450 model. C's have the oil steering clutches and these are superior to the prior models. A 450C is a tremendous dozer and will do twice the work of my 350C. BTW my 350C has 3500original hours and there are machines out there that have 4500 hours or less. i'll give you a good one....if any of the bottom rollers are greasable you have an original low time machine. I still have four of the original ten bottom greasable rollers on my machine. I would say 8K is a lot better price point for the 450. A "C" in REALLY good condition will bring 12 to 15K.
CFWelles
10-18-2004 03:56:03
 Re: Help on buying JD 450 dozer in reply to CFWelles, 10-18-2004 03:48:11
I read your note again and will add that if he can show receipts that this thing had a bonafied major from top to bottom and the undercarriage is like new, you could go ahead with this. If machine is really clean (look at the blade to see if it is all dented up) you could probably go that high. All things being equall, I would look for C. They were the best. The six way if a great set up. Also check the six way out for sloppiness. When the slides wear out, these are quite a bear to rebuild. A tight six way blade setup that doesn't flop back and forth up and down is another good indicator of a well cared for machine.
