2030 tach drive
cowman2
10-15-2004 08:11:26
I"m installing a D 219 in my 23030 and am having a problem with the tach drive the one on the engine is different from the tractor. Can anyone tell me how to exchange the drives from the end of cam.
WTW
10-15-2004 11:49:30
 Re: 2030 tach drive in reply to cowman2, 10-15-2004 08:11:26
There is two kinds of tachometer drive gears used in the two different cams used. The early style is a drive in type that is knurled and is drove into the smooth bore on the end of the cam. Pretty hard to remove the old drive gear to reuse it as you will probably destroy it in the attempt. The later cams have a thread in type and there is two flat spots just under the drive gear teeth where a wrench can be used to remove and install it. It is a common right hand thread. There is a taper at the bolt/base end of gear that seats into the end of camshaft. You may have to purchase the opposite type of gear to make your tachometer work. DW
