4230 split
agri_con
10-15-2004 04:07:40
its a quad,but not sure if this is ome of those babys that has the two upper bolts to the rear trans housings,the syncros are shot,any ideas how I can tell??not sure of the easiest way to split this.
WTW
10-15-2004 07:46:19
 Re: 4230 split in reply to agri_con, 10-15-2004 04:07:40
There is two upper (5/8") bolts in the Quads and syncro's tractors and are found under the transmission cover. These tractors DO NOT require a double split like a Power-shift to get to them. One way to split tractor if lifting equipment is not handy to remove cab, is support rear of cab from above and spit tractor at transmission and roll rear axle and transmission out from under cab. Cab floor will have to be removed to remove transmission cover to get to the bolts previously discussed. A 4230 is more difficult to split this way because the cab is set down closer to transmission compared to other models, but can be done. If equipment and room was not an issue I would pull the cab on this model. Good Luck, DW
agri_con
10-15-2004 15:38:54
 Re: 4230 split in reply to WTW, 10-15-2004 07:46:19
thankfully it only has an op station which was removed today along with rockshaft,have to pull the long hex shaft yet ,i guess from here from what ya say remove the trans to clutch housing bolts and go for the shaft thanks
