2755 need help!!!!!
Pete from Vermo
10-14-2004 15:35:44
The fan belt on our 2755 broke..... how's the fastest way to replace it. Does the radator have to come out ????
SB in AR
10-15-2004 06:04:16
 Re: 2755 need help!!!!! in reply to Pete from Vermont, 10-14-2004 15:35:44
Go to you local bearing distributor and ask to see some Gates Nu-T-Link or Fenner Powertwist. They are a link-type belting, designed to be used as replacements for v-belts in places that are a pain to replace. We sell it quite often to factories to use when they would normally have to remove a large bearing or something on the end of a shaft to replace a set of v-belts. They are not cheap, but they are very good. They should outlast a normal v-belt.
R. John Johnson
10-14-2004 22:14:46
No need to tear half the tractor apart to change the fan belt. Remove the 4 bolts holding the hydraulic punp coupler to the front of the assembly on the front of the crankshaft pulley. This assembly is a fexible drive coupler. Turn the engine 1/4 turn by hand. This should allow you enough room to remove the front portion of the dive coupler and the rubber piece in the center. This should give you enough room to get the fan belt on the pulley. Go to JDPARTS and look up the illustration in the parts manual if my description does not make complete sense.
Hope this helps.
John
