466 head on 404
fredy
10-13-2004 18:47:16
i heard that a 466 head will fit 404 without major changes. is that true? what are the avantages? thanks
WTW
10-14-2004 07:52:32
 Re: 466 head on 404 in reply to fredy, 10-13-2004 18:47:16
fredy, The late 404 and early 466 used the same head. When you get into a later 7.6 / 55 series head the ports and valve size was changed allot including a small cup in bottom of the head over the piston / combustion chamber. This head will bolt down to a 404 block but valves will hit the smaller diameter bore / sleeve. Pullers do use them on 404 engine but requires alteration to make them work. Head bolt patterns on a new 8.1 are still the same clear back to a gas 4010. DW
fredy
10-14-2004 10:09:05
 Re: 466 head on 404 in reply to WTW, 10-14-2004 07:52:32
it sounds like it would be pricey for just a farm tractor
G-MAN
10-14-2004 11:01:39
 Re: 466 head on 404 in reply to fredy, 10-14-2004 10:09:05
Most of the guys putting the 6076 heads on are tractor pullers. Not much advantage to be gained by doing it on a stock 6404, particularly if it's naturally-aspirated. What sort of mixing and matching are you contemplating doing and on what machine?
