John Deere 5020
Bill T
10-13-2004 15:05:12
I recently purchased a 1967 model what BHP is this likely to have 133 or 141? I am also experencing oil getting onto the clutch (not engine oil ) is this a common problem and where is the oil likely to be coming from? How difficult to repaire?
Thanks
Bill
JD Jerry
10-14-2004 05:43:59
 Re: John Deere 5020 in reply to Bill T, 10-13-2004 15:05:12
I had the same trouble with my 4520. I ran it like that for about 5 years (about 500 hours a year) befote I had it fixed. It not to bad of job if you have stands to split it. I took mine to a local shop and the labor was under $400. I had a couple other leaks fixed (steering ram and pump bypass line) new clutch, pressure plate, flywheel turned and throwout bearing. I picked up the parts if I rember right they were around $800.
Kenny G.
10-13-2004 18:54:42
I can't say what bhp you would although it looks like 67 would have been right around the upgrade point for the 5020. The oil you are getting on the clutch is probably coming from the seal between the PTO driveshaft (outside) and the transmission driveshaft (inside). The oil is trans fluid. Repairing requires splitting the tractor in 2 places, engine to bell housing and bell housing to transmission. Remove both shafts and replace the seal that keeps oil from following down the transmission drive shaft and coming out between the two. Of course once you are at this point you might as well check the clutches and their release bearings as well as replacing the PTO break. Good Luck.
fredy
10-13-2004 18:42:39
it should be 133.the oil is probally hy-tran from the pto clutch engagment pistons. had same
trouble with our 72 4000.
DONMYEIL
10-14-2004 11:59:57
 Re: John Deere 5020 in reply to fredy, 10-13-2004 18:42:39
THE 5020 DOES NOT HAVE PTO ENGAGEMENT PISTONS LIKE THE 4000. IT HAS A SEPERATE HYD. OPERATED CLUTCH.
R. G. P.
10-13-2004 17:07:15
Hello Bill. I have an original John Deere service manual on the John Deere 5000 series tractors. Please let me know if you wish more information. Thankyou. Robert.
