J D 350-B diesel loader stalls
Bruce Kreller
10-13-2004 13:59:21
My John Deere 350B diesel loader stalls after running for a couple of minutes and is now stalling after running for just a few seconds. Replacing fuel filters, transfer pump,fuel,and bleeding the fuel system didn't help. Problem still there. I think it must be a problem at the injection pump, but I know nothing about them. I am hoping someone can give me some advice before I pull the injector pump and take it to John Deere $$$. Thanks, BK
Bob
10-13-2004 16:24:08
 Re: J D 350-B diesel loader stalls in reply to Bruce Kreller, 10-13-2004 13:59:21
1.) Do you have constant battery voltage at the terminal on the electric shutoff that remains powered-up even when the engine stalls?
2.) Your fuel shutoff solenoid underneath the pump cover may be bad. Does the pump make a distinct "click" when you turn the switch on, even after it's stalled?
3.) If the plastic governor dampner ring is failing, cruddy black plastic chunks may have plugged the pressure regulator fitting, or the fuel return line. Check for this by REMOVING the fuel return line AND the pressure regulator fitting it attaches to from the injection pump and see if it will run that way. (The injection pump will shut down and not deliver fuel to the injectors, if the return fitting or return line is plugged.) (Caution- be carefull... the return fuel will run out of the pump.)
4.) If the above doesn't help, "tee" into the supply line near the injection pump and attach a low pressure fuel gauge that can also read vacuum. (A gauge for checking manifold vacuum and fuel pressure on carbureted engines will work nicely.)
There should be a steady, low pressure of a few pounds to the injection pump, from the transfer pump and filters. If this reading drops into the vacuum area, you've got a fuel supply problem AHEAD of the injection pump.
Post back after you've checked these things out.
Bruce Kreller
10-15-2004 09:55:13
 Re: J D 350-B diesel loader stalls in reply to Bob, 10-13-2004 16:24:08
Thanks Bob for your help. I have fuel pressure from the transfer pump to the injection pump. There is power to the injection pump shut off and there is a clicking sound when I turn on the key.
I disconnected the return line and the engine ran without stalling. There is no evidence of black rubber junk in the return lines, just clean fuel. I took what looks like a check valve off where the return line connects to the injection pump and blew it out with compressed air. Air goes through it both ways. I also blew out the return line that comes from the engine to the injection pump. Put everything back together and the engine ran for along time, but then stalled again. I am wondering if I need a new check valve?
BK
