Got # 5 Mower Parts ?? (Z-1000-H)
GeorgeK
10-13-2004 11:48:35
Looking for a casting Z-1000-H, It is one cup of a U-Joint between the slip-clutch and the transmission on a JD No 5 Mower.
One of mine is cracked and twisted (actually both are twisted slightly) and I MIGHT be able to straighten it and weld the crack (it is cast, so not very hopeful), but I would rather replace it.
Thanks, GeorgeK
Tom in Mo.
10-14-2004 06:39:01
 Re: Got # 5 Mower Parts ?? (Z-1000-H) in reply to GeorgeK, 10-13-2004 11:48:35
It may be a little far for you to go but at the end of November Aumann Auction in Illinois will have (3)JD # 5 mowers up for grabs, 2 of them for parts and 1 in restorable condition.
GeorgeK
10-14-2004 18:23:14
 Re: Got # 5 Mower Parts ?? (Z-1000-H) in reply to Tom in Mo., 10-14-2004 06:39:01
Thanks for the try, but that is a little far for me, as I am in Colorado.
George
David from Kansas
10-13-2004 18:12:40
Steve,
I've got a couple of JD #5 parts mowers. I think I have what you need, but it will have to wait till a.m. for me to check it out. I would send you both pieces for $10 if you will pay the shipping. Thanks.
David
GeorgeK
10-14-2004 18:15:20
 Re: Got # 5 Mower Parts ?? (Z-1000-H) in reply to David from Kansas, 10-13-2004 18:12:40
Thanks, David,
it looks like the B-319-H might work also, but does not have the proper clearance, would break if angle of bend too much. Really want the Z-1000-H to do it right.
Also need one or a pair of JD-99-H, which is the Joint, Splined Universal (Sub AP-18755-H) for the 1 3/8" PTO. After I stripped the crud off, found a crack in one of these also. The JD-99 is the PTO to U-Joint connection.
The inner shoe is missing it's sole (Z-6058-H) also, if you happen to have one. The outer sole I can weld a new bottom on it.
Let me know what you fine, I left my email open on this response,
Thanks, George
Steve-n-GA
10-13-2004 17:47:31
Try Dave Cook (in Wisconsin) 715 373-2092 or>Link
Good Luck
Steve Doan
GeorgeK
10-14-2004 18:20:16
 Re: Got # 5 Mower Parts ?? (Z-1000-H) in reply to Steve-n-GA, 10-13-2004 17:47:31
Thanks for the site.
There is now an 800 number listed for them on the web.
1-800-578-1480
Thanks, George
