2010 hydraulics following rockshaft rebuild
farmergreen
10-13-2004 10:44:29
Rebuilt dual rockshaft assembly. Replaced all o-rings, seals, and snap rings holding valves. Rockshaft and power steering worked upon re-assembly. Raised a 6 foot bush hog to further test system, all okay. Next day rockshaft and PS failed and fluid poured out of weep hole in the pto clutch chamber. Found that a new snap ring in a rockshaft valve had dislodged causing the leakage. Replaced ring. Lift and PS worked fine for one hour. Now, no PS, no lift, but no leaks.
farmergreen
10-21-2004 11:09:23
 Re: 2010 hydraulics following rockshaft rebuild in reply to farmergreen, 10-13-2004 10:44:29
Problem solved, see post at:
http://www.ytmag.com/jd/messages/147874.html
