JD 50 cam followers sticking?
Jack H.
10-13-2004 08:32:37
While adjusting the valves on my 50, I noticed that both valves on no. 2 cylinder would hesitate while closing and then snap closed. The rocker and pushrod never got loose when this happened, leading me to think the valves were not sticking.
Could the cam followers be hanging up? Or is this normal? Seems coincidental that both valves on the same cylinder are doing this.
Thanks
John Van Valkenburgh
10-13-2004 18:04:01
 Re: JD 50 cam followers sticking? in reply to Jack H., 10-13-2004 08:32:37
Jack,
This does not sound normal to me. Try loosening the valve adjusters all the way such that the rocker arm is free. Then crank over the engine by hand until the pushrod comes out it's normal distance. Crank the engine around some more, say 180 degrees and then try pushing the push-rod back against the cam follower. If it does not go smoothly then you've got a problem.
Just an obvious thought but you do have both spark plugs removed right?
Best of luck,
John 1953 Model 50
Jack H.
10-14-2004 04:40:44
 Re: JD 50 cam followers sticking? in reply to John Van Valkenburgh, 10-13-2004 18:04:01
Yes, I do have both plugs out. That is a good idea , I will try it tonight. That should help isolate the problem. Thanks John
Jack
