430 Wiring
Deere Heaven
10-13-2004 08:06:44
I am trying to finish up the wiring on my Jd 430. On the wiring schematic I have it does not show the wiring to the oil pressure sender or the guage. MY tractor does not have a key switch. Thanks, Brian
JD430Dan
11-02-2004 04:14:24
 Re: 430 Wiring in reply to Deere Heaven , 10-13-2004 08:06:44
I could sure use a copy of that diagram. I would be willing to pay you, so please email me at [email protected] if interested. Thanks.
John T
10-13-2004 08:58:18
Deere, Im not exactly what you have there, but most "electrical" gauge and sender units (NOT the capillary tube mechanical type oil pressure or heat gauges) work by having voltage applied to the gauge when the ignition is turned on, and then current flows to and through the gauge and then to the sender which supplies the ground return path for gauge needle deflection. My best guess (NO warranty) is if you have an electrical gauge it needs to be fed a hot wire ONLY when ignition is ON (so it dont draw current when tractor off) and then the gauges output is wired down to the sender with one wire and the gauge body is the ground. Even without a key switch, there has to be a way to feed the coil when ON so that could be a possible source of switched voltage to power up an electrical gauge and sender is what Im thinking for now, sorry, i have no 430 diagram either.
Good Luck n God Bless
John T
