Aneroid and pump
Tx Jim
10-13-2004 05:09:49
Johnsdeere,back when 4430's were new they didn't start great in cold temps.If it has mechanical aneroid on side of inj.pump that I remember JD said after killing engine to open throttle wide open then back to idle position.Doing this while warm would help set pump to start position.Also this trips the aneroid linkage outside the pump.The inj. pump could be a little off on timing due to gear wear.I agree with other posts that injectors should be checked.Tx Jim
Johnsdeere
10-13-2004 17:28:25
 Re: Aneroid and pump in reply to Tx Jim, 10-13-2004 05:09:49
How do I tell if it has a mechanical aneroid on the pump? Should I remove the injectors and have them rebuilt? or replace them? What does this cost?
