JD B Spark Plugs
Big Yarber
10-12-2004 19:39:35
could anyone tell me the correct gap for a 1952 JD B spark plug. mine are gapped at 44 and it runs fine but what was the factory. ( i have the heavy duty set of plugs)
John T
10-12-2004 19:47:44
 Re: JD B Spark Plugs in reply to Big Yarber, 10-12-2004 19:39:35
Yarber, the factory tune up spec is around 0.030, however, I run mine around 0.035 with standard equipment ignition. In the case of elec ignition and high energy coils, then I would run in the 0.040 to maybe even 0.050 range, but still within the ignition vendors specs. Use wire core and NOT carbon core suppressor type wires. I usually run a heat range or two hotter plug (say maybe an Autolite 388 versus a 386), especially if its used for light duty.
Good Luck n God Bless
John T in Indiana
GERRY G
10-13-2004 16:38:38
 Re: JD B Spark Plugs in reply to John T, 10-12-2004 19:47:44
IS A AC C88L A HOT PLUG A 1941 B
John T
10-13-2004 20:23:04
 Re: JD B Spark Plugs in reply to GERRY G, 10-13-2004 16:38:38
Gerry, Hopefully Duane Larson, the real Spark Plug Guru, can corect me if Im wrong as I have no plug cross reference data available, but I believe that AC plug is equivalent to the Autolite 388 WHICH IS INDEED one heat range hotter then the standard 386.
John T
