update of JD A push rod oiling problem.
nathan kehler
10-12-2004 19:21:07
HI,thanks for the help,i should have put it a little different. the oil tee line to the rockershaft has a good supply of oil coming out but this is below
the push rod adjustment bolts, they stayed dry. the oil was milky from water leak(now sealed and oil changed) did this stop the oil from splashing from the crank down the rods to the rockers?
F-I-T
10-13-2004 06:46:43
 Re: update of JD A push rod oiling problem. in reply to nathan kehler, 10-12-2004 19:21:07
Nathan:
That could be the case, but running them at lower speeds or idling alot will inhibit the splashing of the oil as well.
Might just need to run it faster.
Frank
