Any suggestions on connecting No 5 mower on a 46 J
GeorgeK
10-12-2004 18:33:42
Got an "A", just got a #5 mower to rebuild.
Looking for suggestions on the adapters used to attach to the "A".
Does anyone have any pictures of adapters?
Thanks, GeorgeK
BAM BAM
10-14-2004 16:50:59
 Re: Any suggestions on connecting No 5 mower on a in reply to GeorgeK, 10-12-2004 18:33:42
Get the operators manual from JD. You'll need it to go through the mower anyway. Lots of good info on mounts. I made a mount that mates my pre war #5 to the 801 hitch on my 70. Works like a champ, and goes on/off quick.
jd68
10-13-2004 17:44:18
George send me your email adress and I will send u a .PDF file I have that shows and tells you everything you need or would want to know about building a hitch and how this mower should mount up to a tractor.
GeorgeK
10-14-2004 17:43:54
 Re: Any suggestions on connecting No 5 mower on a in reply to jd68, 10-13-2004 17:44:18
You should be able to pick it up from this reply.
Thanks, G
dwm
10-12-2004 20:32:07
I know of two kinds of hitch for the No. 5. For your tractor, the earlier No. 5s have a flat bar meant to set on a pair of L shaped brackets that bolt to either side of the drawbar with two bolts on each side. The horizontal flat bar on the mower then has one bolt go through each bracket. This would assume your '46 A has the correct drawbar (I've seen some with a later one).
The later No. 5s have what they called a 'quick-tach' of sorts. It has two clamps made to clamp onto two round horizontal pegs sticking out from either side of the As with the later drawbar. The brackets that go onto the tractor bolt flatways only on this 'newer' style drawbar--I believe it would have started with the '47 As. In other words, you first have to determine which hitch you have on your No. 5. I've seen both kinds of mounting brackets at auctions etc.
RalphinWI
10-12-2004 21:34:06
 Re: Any suggestions on connecting No 5 mower on a in reply to dwm, 10-12-2004 20:32:07
Our A (578383 Nov. '46) came from the factory with the later style drawbar so they must have run out of the old style drawbnars. Two 3/8" plates were welded to the original L-shaped brackets from a '41 B. This was used until a quick-tach was fitted to the # 5.
GeorgeK
10-12-2004 18:37:18
 That's a 46 JD A in reply to GeorgeK, 10-12-2004 18:33:42
IT CHOPPED MY SUBJECT LINE....
