77 500C b/hoe won't start after replacing alterna
Ed
02-06-2004 21:17:56
After trouble shooting the charging system,and the alt light being on, I changed the alt.reg and now the backhoe won't start from the push button. I can start it by crossing the starter contacts, but not the start button.
I am wondering what could possibly have happened from the time I changed the alt to now?
I am going to try to follow the wires and see what if anything happened.
Has anyone had this happen or heard of it? Thanks for your help.
Ed
adam
07-06-2004 20:31:17
 Re: 77 500C b/hoe won't start after replacing alt in reply to Ed, 02-06-2004 21:17:56
hey buddy, i had this problem wiht my grass hopper zero turn lawnmower what is wrong with your backhoe is i think if when you hear a clicking noise when you turn the ignition on and try to start it then their is a little box near the starter that has a contact in it that has probbouly worn out if you have lift it out side so what you should do is open up the little black box and bend the contact closer to the other contact then try that or replace the box.
old
02-07-2004 08:42:55
Yep, sounds like you got a wire on wrong or when doing the work you pulled one off from some where. I've seen that so many times, they can be fun to find also, its probably something very simple so look close
