DLTX 33 to 18. Will it work?
chrisfromsolitude
10-12-2004 10:41:12
I have a 1950 A that I broke the 33 carb on. My question is can I use the float and butterfly valve from the 33 in the 18? Also will a 18 work on my tractor or not. Any help is appreciated.
Maark
10-12-2004 21:39:04
 Re: DLTX 33 to 18. Will it work? in reply to chrisfromsolitude, 10-12-2004 10:41:12
The float will work, but neither the choke plate or the throttle plate will work. The needle and seat will also work. The 18 carb will work, but not perform as well as the 33 on your tractor. That carb can be repaired by cutting the end off a spark plug from an unstyled A or B. and brazing or silver solder in place. A Champion w-18 plug works well for a donor
chrisfromsolitude
10-13-2004 06:56:29
 Re: DLTX 33 to 18. Will it work? in reply to Maark, 10-12-2004 21:39:04
Thanks for the advice. I will try it and see what happens this weekend. Thanks again and have a nice day.
