Frozen A Brake
jdman(MO)
10-12-2004 10:21:43
Everything frozen, pedal, adjuster, drum. Tried a lot of penetrating oil and some heat. How about dumping it in a bucket of diesel? Russ
JDPete
10-12-2004 19:00:01
 Re: Frozen A Brake in reply to jdman(MO), 10-12-2004 10:21:43
I have had a few that were rusted solid. I have had the best luck getting them loose by soaking with penetrating oil then clamp the assembly in a vise. Then use a strap wrench on the drum and break it loose. Unless it was rusted with the brake locked, it should move. If it only moves a little, just keep working it back and forth. After it turns, remove the gear from the shaft and work the drum off. At this point it becomes a lot easier!
donwisc
10-12-2004 16:37:41
I have a complete brake assy that came off a unstyled A. Every thing was freed up and the pads are good. If you are interested please EM me and we can discuss.
This could save a lot of time and work unless you want the "fun" of restoring your brake.
jdman(MO)
10-12-2004 19:41:06
 Re: Frozen A Brake in reply to donwisc, 10-12-2004 16:37:41
See how I make out tommorrow. I suppose the brakes are the same on the unstyled as the styled. Think this one is a 41. Russ
