1950 Electrical problems
Rons Old A
10-12-2004 09:50:23
Ive got a 1950 A that had the generator rebuilt and I had the guy show me on the stand that its polarized correctly(positive ground) yet when I hook up the positive battery cable the amp meter goes full discharge. Do i have a short somewhere? also when its in full discharge mode the starter won"t spin, disconnect the batt wire from the generator and it turns over perfect but I also dont have any spark. When he first rebuilt it he didnt replace the regulator which stuck (he says) burnt up the armature, now thats all fixed and the generator charges great on his stand but now I have this problem. What could be fried? being I have no spark could my coil be burnt up? I have the battery hooked up correctly positive ground, by the way, NAPA didnt have 2 sixes so I bought one twelve, now this shouldnt make any difference right? I have the battery hooked up ground cable to the positive terminal of the battery, starter cable to the negative post.Plwease help Im at my whits end By the way, the tractor had great spark, ran fine when I first took the generator off, and since Ive got a hornets nest.
John T
10-12-2004 16:35:19
 Re: 1950 Electrical problems in reply to Rons Old A, 10-12-2004 09:50:23
Ron, were gonna first have to figure out that heavy discharge when you hook up the battery. If the cutout relay is stuck/burned closed, the Generators armature (low resistance) draws heavy battery current and if wired correct that would show up as a heavy discharge when the tractors setting. That cutout relay (regardless if inside a VR or a stand alone) is SUPPOSED to only close when the Gens output exceeds the batterys, but then open like when tractor sits so it dont reverse discharge the battery via the armature winding. If when you unhook the wire from the load (NOT to battery) side of the ammeter that runs down to the BAT terminal on the Voltage Regulator (or cutout relay) the discharge stops, either the cutout relay is bad/stuck closed or, if its only a 2 wire cutout relay, it may be wired the wrong polarity. If unhooking the wire from the ammeter to BAT on the VR or cutout relay stops the discharge, try that first and then see if she cranks okay and if she fires the plugs, then we will troubleshoot any no fire problem and the charging system. If shes drawing a heavy discharge via a bad or incorrect relay or VR, plus the starting motors drawing high current, that can be cause for a weak spark.
Heres some things I need to know in order to better help you, as I have seen many changed over and jury rgged electrical systems, regardless of how shes SUPPOSED to be equipped: Do you have a full fledged 3 or 4 wire Voltage Regulator (BAT ARM FLD maybe LOAD terminals) or only a small 2 wire cutout relay (BAT and ARM)??? What ignition system you have?? Sounds like a battery powered coil ignition form what you say, but is it a Delco?? A 2 wire cutout relay needs to be compatibe with your ground (pos or neg) although many will work either way. REGARDLESS, it still has to be wired correct to work.
Theres no problem in runnign the single 12 volt battery versus two sixes in series.
Let me know what ignition you have,,, and if a VR or 2 wire cutout relay,,, and if unhooking the wire to BAT on the relay or VR stops the discharge, n we will go from there.
PS I also wonder if shes wired correct??? Do you have a schematic?? You could still have a short as you asked, but do these preliminaries n then we will proceed.
Good luck n God Bless
John T in Indiana
Rons Old A
10-13-2004 06:42:39
 Re: 1950 Electrical problems in reply to John T, 10-12-2004 16:35:19
Hi John, I only have two wires to hook up to the voltage regulator, It is a delco remy distributer, the new voltage regulator he put on says,"Works with positive or negative ground " I'm sure that the discharge stops when the generator is'nt hooked up.
The wireering should all be the way its supposed to be as the tractor was working great for many years, I hope you can help me get to the bottom of this mess. Thanks and god bless you as well!
John T
10-13-2004 07:02:12
 Re: 1950 Electrical problems in reply to Rons Old A, 10-13-2004 06:42:39
Ron, in that event I think the 2 wire cutout relay you have is wired bass ackwards. The generic bipolar 2 wire cutout relays (its not a 3 or 4 wire Voltagr Regulator) can work for EITHER ground, but they still gotta be wired correct, and it sounds like yours may simply need reversed. On those type systems, the Field off the Generatotr gets wired up to your light switch for low charge when lights are off but high charge if lights are on. If she wont charge, that wire may be missing or the lights switch is bad or not wired correct, better fix the relay wirign then re post back on a front page with any remainign no charge or no fire problems.
John T
