A backfiring
donwisc
10-11-2004 21:52:52
Just finished a Unstyled A and started it up to nite. It has a good rebuilt mag and reconditioned carb. The pipe has not been connected from carb to aircleaner so intake is direct into the carb.
It starts up ok and runs but periodically backfires and Ill get a puff of smoke out the carb.. the guy that rebuilt the Mag thought the butterfly plate was worn and shaft needed to be rebushed, there is a lot of end play.
Is it possible this is causing the rough running?
The mag impulse was set according to instuctions.
Thanks for any input
Lee B
10-11-2004 22:57:52
 Re: A backfiring in reply to donwisc, 10-11-2004 21:52:52
I"d say it was unlikely for a worn throttle shaft to be the root cause of the backfiring. Usually backfiring is due to a lean mixture but it can be forced to happen for mechanical reasons like sticking valves or no valve lash. I would double check that all the valves are operating freely, have .020 for lash and check their oiling. Especially if richening the mixture doesn"t seem to get you away from the backfiring. The valve check should be done anyway, especially if went in there during the "build".
