37 D smoking
Austin B
10-11-2004 20:26:34
My dad has a 1937 D and it smokes blue smoke out the #2 cylender only. When we tried to put it on the baker fan it wouldnt run it at all. However the previous year it ran it great and then we put it away for winter got it back out and it started backfireing and smoking heavely out the #2. The timeing is right on even tried three different mags and changed the spark plugs too many times to count. We also had the carb rebuilt and it continues to backfire, miss, and blow a ton of blue smoke out the #2 cylender. The tractor still has good compression and runs fine until it is warmed up. But when you put any kind of load on it it does not fire and just blows oil out the petcock. Is there a possibility the oil ring could have broken? Also when I took the petcock out and looked at the rings there was quite a bit of movement of the rings back and forth in the ring groove. Any Ideas? Thanks!
