JD 60 Rock-Shaft operation..???
BushogPapa
10-11-2004 19:18:45
Neighbor has a problem with his Rock-Shaft (3-point) operation... On the "60", is there a seperate setting, to switch from "Remote Cylinder", and Rock-Shaft operation, other than switching the hydrolic plugs..?? He has Pioneer plugs, plumbed into the side of the power-trol...and using the "dummy plugs" he gets good use of his remote cylinder, but is not able to get his rock-shaft (3-point) to work properly...he can't get it to lift a post hole digger..and that is not heavy at all...!! Thanks, he can use the help..!! Ron..
Dan in Ohio
10-12-2004 04:45:36
 Re: JD 60 Rock-Shaft operation..??? in reply to BushogPapa, 10-11-2004 19:18:45
There is a metering screw on the left side of the powertrol unit, turn it clear in for cylinder operation or two turns out for rockshaft operation.
BushogPapa
10-13-2004 06:10:51
 Re: JD 60 Rock-Shaft operation..??? in reply to Dan in Ohio, 10-12-2004 04:45:36
Thanks, Dan for the good info..
Where in Ohio are ya located..??
I am just North of Columbus Ohio..
