510B (4276T) engine interchange/repower
Hot Rod Rolls
10-11-2004 17:40:20
I have a 510B Back hoe that I love. Recently, the engine developed a horrendous noise. It sounded like a rod knock only worse. It still runs perfect with excellent power. I pulled the pan and found that the oil pump pickup tube was demolished so I decided to replace the tube and rebearing it and hope for the best. When I pulled the mains off, the crank moved enough to show that it was cracked completely in two near the center main. I'm sure the vibration from this is what destroyed the oil pickup. My options are to rebuild, buy a used engine, buy a rebuilt engine or buy a brand new engine. Rebuild is $3000 for parts and a bunch of time. Used 4276T engines are hard to find. Rebuilt long blocks are anywhere from $3500 to $6000 plus core charge (since my crank is junk). New 4276T engines don't exist but new 4045T engines do. My question is will this 4045T engine bolt up into my tractor? What other engines do bolt up (if any)? Does anybody know if the 4045T Powertech diesel would bolt up? I can fabricate just about anything but I don't want to get into making an engine adapter. Jeesh, this is long. Sorry about that.
Chas
cannonball
10-12-2004 07:39:44
 Re: 510B (4276T) engine interchange/repower in reply to Hot Rod Rolls, 10-11-2004 17:40:20
jd 2630 and 2640 use 279
HTR
10-11-2004 19:31:36
The 4279 and the 4045 (4.5 liter, 279 cid) engine are basically the same engine. They will interchange. Any of the three hundred series will bolt in, 202, 219, 239 same as 4039, 4045, and the powertechs. We have over thirty of these engines to keep going for one company, (forklifts) plus a lot of the tractors in the area.
We really have had better luck with the old 279s, and the old 4054s than we have with the powertechs, oil consumption problems at about 2000 hours.
If you do rebuild, don't buy an India made crankshaft!!
Hot Rod Rolls
10-13-2004 11:04:34
 Re: 510B (4276T) engine interchange/repower in reply to HTR, 10-11-2004 19:31:36
Additional information... I finally got a John Deere rep. to give me the lowdown on this swap. I had to believe there were people (other than us) who have done this conversion or are considering doing it. The rep. first tried to again convince me to buy reman. She then told me that the conversion was a lot more trouble than it could possibly ever be worth (I once adapted a mercedes diesel to a JD 2010 - worked excellent but way too much power). I then got out of her this information:
1) Bottom radiator inlet has to be moved to other side (or a bypass hose fabricated).
2) Radiator cap has to be changed to 10# pressure cap.
3) Temp gauge probe has to be moved to thermostat housing (needs part # 10005951 metric adapter).
4) Fan spacer needed to keep fan from hitting crank. (?)
5) Cooling capacity of radiator needs to be sufficient for new engine.
6) Powertechs cannot be used where structural blocks are required.
7) Metric bolts and adapters (except flywheel bolts which are still 3/8").
8) Powertech engines measure 3/4" longer from face of block to fan. (?)
9) Auxiliary drive on opposite side.
I don't know about you but these are all easily dealt with. #1-#5 and #7 are common sense. #6 is important for tractors (not TLBs with a full frame like mine). #8 may effect how the front motor mounts line up. I am sure this can be fixed by milling the front mount brackets 3/4" or redrilling the holes for the resilient mounts. #9 is important only if you need auxiliary drive which I do not. I'd rather do all of these things 5 times than make an adapter plate.
The biggest reason I am pushing for this conversion is because I can purchase a brand new (left over - overstocked) 110 hp 4045T for $5300. You can't completely rebuild (parts and labor) for that.
Thanks again and I'll let you know how it comes out.
Chas
Hot Rod Rolls
10-13-2004 08:39:52
Thanks for the help and for giving me hope. I just want to verify that my 510B has a 276 (not 279) motor. I have talked with some John Deere salesman and they want to either sell me a 276 reman motor or a new back hoe. They have even told me that the powertech swap cannot be done. If the engine will receive my old flywheel housing, flywheel and hopefully front pump drive then I am in. It looks like the injector pump is a one wire deal and it is running. Is there such a thing as a non powertech 4045T?
