dieselrig
10-11-2004 19:30:42
Re: JD 50 rough idle in reply to John Van Valkenburgh, 10-11-2004 18:53:06
Make sure you have the right carb for your tractor, what I mean is, make sure it is not an all fuel carb, if it is, it will most likely never idle right,no matter what you do to it, most likely you have a plugged idle passage, there should be 3 small holes in the bottom side of each barrel in your carb, on the throttle side, if you cannot find 3 very small holes, dig around some to locate them, the one closest to the gasket side is where you idle screw for each cylinder goes in, the others are one ahead and one behind the throttle plate, use pb blaster to get into these to check for pluggage, and a fine air nozzle like to fill a basketball, use this to run high pressure air in these small areas, there are also two 7/16" softplugs on the sides of the carb stem and one in the center between the choke plates, take these out and clean the crud out , this will help , get new softplugs as the ones you take out will be junk , so have these before you start, the big plug on top of the carb can stay in as it doesnt pay to remove it , as you can get the all the bad areas with the plugs removed as stated earlier, good luck.
