4020 doesn't start after warm
Big E
10-11-2004 10:28:30
I have a late model 4020 that starts ok when cold, but not when warm/hot. It has to sit approx 30 mins before it will fire up again. It will crank when warm, but only cranks for about 10 secs and winds down. Plz HELP
Joe P.
10-12-2004 05:12:05
 Re: 4020 doesn't start after warm in reply to Big E, 10-11-2004 10:28:30
My 3020 did the same thing. I found the problem to be a bad neutral safety switch (powershift). I bypassed the switch and it works fine. In one of my manuals the troubleshooting section listed "high resistance in the starting circuit" as a possible problem and when the transmission would heat up, sure enough it would increase the resistance of this faulty switch just enough to put a serious drag on the starter.
Big E
10-14-2004 11:50:29
 Re: 4020 doesn't start after warm in reply to Joe P., 10-12-2004 05:12:05
Where is that switch located, isn't it under the dash near the gear selection lever?
msb
10-11-2004 21:34:35
I suspect you have some corrosion on your battery terminals or a bad cable or two.Look for bulges on the cables that would indicate corrosion under the insulation.Try jumpering across each cable with a jumper cable to try locating the bad cable.Also try rocking the steering wheel back and forth as you crank.You could have a plugged bleed off hole inside the priority valve.
HTR
10-11-2004 19:00:58
Get rid of the Delco starter, and get an Iskra. They will crank it fast enough to start, hot or cold. You will need a longer ground cable, as the ground stud is on the starter.
Most starter alternator repair shops carry this brand. SpareX also sells the Iskra brand. It is at least one good product they sell.
The Delco starter was never satisfactory after the first year on the 4020, 12 volt tractor.
Also less expensive than the Delco.
rctn
10-11-2004 16:18:17
I had the same problem on my 4000 and my buddy on his 4020. He needed a starter rebuild and mine needed a solinoid rebuild and both start great now.
DP
10-11-2004 11:14:50
I am guessing you are talking about a diesel. That sounds like an injection pump that is getting weak. Don
Matt in WA
10-11-2004 16:40:11
 Re: 4020 doesn't start after warm in reply to DP, 10-11-2004 11:14:50
My 1969, 4020 diesel did the same thing last summer. After having the starter rebuilt it starts well now. The starter shop said the brushes were very worn out, and likely was the original starter. A friend told me that when they are worn, and near the intake manifold, (as they are on mine), they lose more contact when warm, and then get better after contracting, from cooling down. Just my $0.02. Let us know what you find.
