2840 hydraulics pressure tests
jerryGA
10-11-2004 07:30:19
thanks for the help and information so far. i would like to know more on pressure testing the transmission pump system before i decide to split tractor. once again, i was mowing with tractor. i used the right brake to turn when i heard mower slowing down. i turned off pto and began driving to shed and only made it about 100 feet when tractor stopped pulling and a whining noise was heard.
jerryGA
10-11-2004 09:10:30
 Re: 2840 hydraulics pressure tests in reply to jerryGA, 10-11-2004 07:30:19
i've lost all hydraulics. no power steering, lift, remotes, pto, and tractor will only move a few feet before slipping. i know some of you have already answered some of my questions. but someone mentioned pressure testing certain lines before splitting. please explain further. thanks, jerry
Bob
10-11-2004 08:15:13
A genuine Deere service manual is not cheap, but neither is attempting to fix a system as complex as this, without having needed information at hand.
The manual will give you all system pressures and flow rates, as well as color-coded oil circuit diagrams, so you can track down your problem.
Tech manual #TM4336, $40.00 on CDROM, or $75.00 paper, call Deere at 1-800-522-7448, or check ebay.
