3300 combine carburator
TJsdad
10-09-2004 19:30:19
I recently bought a 3300 combine. It ran fine when I parked it, but now it will not start. It will run on starting fluid. It pumps gas up to carburator when the key is on. There is an electric piece screwed in the bottom of the carburator that was replaced last fall by the previous owner. How do I check this piece out to see if it went bad again? It has something to do with the needle valve, I think. Can this be done away with? Thanks - Jeff
Doug in IL
10-11-2004 05:36:12
 Re: 3300 combine carburator in reply to TJsdad, 10-09-2004 19:30:19
Yes, The electric fuel shut off can be done away with. The screw in the bottom of the electric valve adjusts the fuel mixture. Deere sells a manually adjustable needle valve to replace the electric one. I have put them on a 3300 combine and a 2020 tractor that I used to own. I have one on a 2510 tractor I still own. It is the way to go. The manual valve is roughly a third the cost of the electric one. And they never go bad. I have never experienced engine run on with them either. Just keep the idle speed low for shutoff.
dieselade
10-11-2004 04:31:50
I had a 3300 for several years. I usually had to tap the carb with a hammer lightly , I guess to shake loose the float. then it would work fine. I never had trouble with the selenoid.
Bob
10-09-2004 20:09:23
The "electric piece" is a fuel shutoff solenoid, used to prevent backfire in the muffler, or dieseling, when the engine is shut off hot. When 12 Volts is applied to it, there should be a small, but distinctive "click" as it pulls back the needle out of the main jet.
The inlet needle valve in the carburetor may by plugged with crud, or stuck shut, or there may be water in the float bowl, or the electric fuel shutoff solenoid may be electrically defective, or just stuck shut. (Have you verified that there's power to it with the ignition switch "ON"?)
TJsdad
10-10-2004 06:54:21
 Re: 3300 combine carburator in reply to Bob, 10-09-2004 20:09:23
Thanks for your info !! No I have not checked for power yet. I will do that today. I will let you know what I find out. - Jeff
TJsdad
10-10-2004 18:23:17
 Re: 3300 combine carburator in reply to TJsdad, 10-10-2004 06:54:21
I checked for power, & yes it is there. I then removed unit from carb and it clicks lightly when turning the key switch on & off. - Jeff -
Bob
10-10-2004 19:36:36
 Re: 3300 combine carburator in reply to TJsdad, 10-10-2004 18:23:17
When you removed the solenoid from the carburetor, did a half-cup or more of gasoline drain out of the carburetor, indicating that the float bowl was properly full of gasoline?
(Be carefull around that carburetor, with the electic power there, besides! Don't ask why I say this!)
TJsdad
10-11-2004 05:22:28
 Re: 3300 combine carburator in reply to Bob, 10-10-2004 19:36:36
No, there was no gas running out. - Jeff -
Gerald J.
10-11-2004 07:41:21
 Re: 3300 combine carburator in reply to TJsdad, 10-11-2004 05:22:28
No gas, means the fuel line is closed. Could be a stuck float, a worn and sticking float needle (and seat), the inlet fitting screen plugged with varnish, the line plugged with varnish, the fuel filter plugged with water or varnish, the strainer at the tank plugged with rust, butterfly wings, or varnish, and/or the tank vent plugged. Engine won't run with the float bowl dry.
Gerald J.
