G JD Any GOOD
Marko
02-06-2004 10:38:12
Found JD G are they a good tractor or not. Do they have any problems to look for.
Eric F
02-07-2004 16:23:34
 Re: G JD Any GOOD in reply to Marko, 02-06-2004 10:38:12
Gs are my favorite. Some things to look for are, Clutch drive comes loose an ruins the splines on the crank. Third and forth gear will be noisey if the cluster gear is rough or the bearing is bad. Some of the Gs have a cracked head if they were shut off too hot. Hope this will give you some things to check. Whatever you find it can be fixed. I think they are the best to restore or to pull. Good luck
buickanddeere
02-07-2004 08:55:23
While the "G" has probably more fans than it's decedents the 70 and 720/730 put together. It's main claim to fame is being able to burn anything that pours while pulling heavy loads year after year reliably. Lightweight/HP for pulling classes too. As far as power steering, live hydraulics, live pto and reliable cooling in hot weather when heavily loaded, fuel efficiency on gasoline..... ..... nope. A 60,70,620/630,720/730 optioned with live pto and powersteering will do more on less fuel. A full three point hitch on the later models too.
Eric H
02-07-2004 04:34:48
I concur with the below, there isn't a G around that I wouldn't love!!! I have a 1950, Dad has a '47 and '52. Truly tyhe horse of the letter series tractors!!!
R/
Eric
Roger
02-06-2004 22:23:27
I never saw a G that I didn't like, especially since I have one
Mike M
02-06-2004 11:49:44
I would say a lot depends on what you want to do with it ? Good for some things and not worth a darn for others.
