2640 Hydraulics
JD Jim A.
10-09-2004 15:24:50
Hi, I'm looking at purchasing a 2640 Utiity tractor. Today while looking at it, I noticed that the main hydraulic pump sounds like it's pumping all of the time. Shouldn't that pump shut itself down when no hydralic functions are being used? Is there any quick way to tell if what I am hearing is truely the pump pumping? All of the fuctions seem to work fine- hitch goes up and down, steering works great, the remote outlet works, it's just that I don't hear any change in the sound it makes when I put a hydraulic function on demand. I left the tractor running for about half-an hour, then I started feeling any line I could get my hands on, and everything stayed cool. Just looking for a cheap, easy way to tell if everything is all right, I don't want to spend anything testing a tractor that isn't mine yet, and the owner says "it's never given any trouble". I'm not saying I don't belive the guy, I'm just not sure what these things should sound like.
Tx Jim
10-10-2004 06:14:39
 closed center hyds. in reply to JD Jim A., 10-09-2004 15:24:50
JD Jim A,the main hyd. pump turns while engine is running,but if a hyd. function is not being used or there is no internal leak the pump goes out of stroke and stops pumping oil if stroke control valve is operating properly.Feeling for heat and being cool is a good sign that all is well.Steering and rockshaft valves are where alot of internal leaks occur on closed center systems.Closed center hyds. were said to cut down on fuel use but on larger JD tractors with hyd seat,steering,lifts I think that the pump didn't stay out of stroke long.Good luck on your purchase.Tx Jim
Dieselrider
10-09-2004 17:08:01
 Re: 2640 Hydraulics in reply to JD Jim A., 10-09-2004 15:24:50
The hydraulic pump on these provide pressure to the transmission and pto and I believe they run all the time. As long as things aren't overheating everything is probably ok.
buickanddeere
10-10-2004 20:15:27
 Re: 2640 Hydraulics in reply to Dieselrider, 10-09-2004 17:08:01
The "low pressure" transmission charge pump engaged the pto, diff lock and shifted the transmission.
