Help! Gear shifter snapped off.
Flint
10-09-2004 06:06:57
I was putting my JD 60 in gear and the lever broke off. Does anyone know how to replace this lever and will I be able to purchase a new one? Any help would be appreciated.
billyiron
10-09-2004 06:36:51
 Re: Help! Gear shifter snapped off. in reply to Flint, 10-09-2004 06:06:57
I never had a 60 apart but should be close to an A,, need to take shift tower off, lever comes out thru bottom, theres a snap ring under the shift patteren on the lever,remove that and it should come out the bottom, theres a dust cover and spring also,,I dont know where yours broke, but guessing you have the piece with snap ring in your hand,,not a big deal to fix, may find one at salvage yard,,,,, ,,,,billyiron
Flint
10-09-2004 21:27:50
 Re: Help! Gear shifter snapped off. in reply to billyiron, 10-09-2004 06:36:51
Thank you for the information. If I may pry a little further when you say remove shift tower does that involve the dash panel and everything above it? Does the lever come out by way of coming up through the transmission cover?
billyiron
10-10-2004 07:18:34
 Re: Help! Gear shifter snapped off. in reply to Flint, 10-09-2004 21:27:50
Im a little in the dark on a 60, havent paid close attention when I seen one, I think the casting with the shift pattern and dash panel and also is holding steering wheel is one piece so all needs to come off, the shift lever comes out the bottom of that piece,,the dash assembly casting may bolt to the shift pattern casting with 2 bolts;; I hope someone who knows the 60 a little beter than I will post,,billyiron
Flint
10-11-2004 19:28:12
 Re: Help! Gear shifter snapped off. in reply to billyiron, 10-10-2004 07:18:34
Thanks billyiron and FIT for the verbal description and picture. I got it apart in a 1/2 hour with no frustration. I'm noticing some wear on the reverse guide and it has been built up with a weld. Reverse can be a little hard to get into but does work so I'm undecided on doing any more. I suppose that could be another post.
F-I-T
10-10-2004 07:54:00
third party image
Fella:
Here's a diagram of the 60 quadrant. I think you can block the dash up and jiggle the quadrant free, but that's a guess on my part based only on this picture.
Frank
RickB
10-11-2004 14:59:13
 Re: Help! Gear shifter snapped off. in reply to F-I-T, 10-10-2004 07:54:00
That works on a 730D.
